I just set the mainboard performance profile to performance load.... Lazy I know. It ups it to 3.8.
I simply went into the Bios and selected the "Performance" profile. It overclocked itself, I didn't do anything other than that.
What are the parameters? I mean LN2 guys are only getting 5.4-5.8g on these chips, things were made smaller, electron migration is more an issue now, with less material to insulate the internals of the CPU. But water-cooling is getting the same result as air, just at lower temps. There is something else inhibiting overclocking potential, not just the CPU physical limitation, but some instruction within the CPU itself that thinks if temp "A" and temp "B" are at a difference of more than "X" degrees then freq. limitations are enforced, but if temp "A" and temp "B" are at temp "X" or less then frequency limitations are lifted until temp "X" is reached or exceeded.
Like you said, you had the same clock with two different temps, but at about the same difference, say that difference is 30c if you can lower that CPU sensor temp to within 10c of the CPU temp then maybe you will achieve higher clocks?
Yes I know we don't know what the CPU sensor is reporting so it makes it difficult to determine how to cool it.
I find it hard to believe that two different boards with completely different power capabilities achieve the same end result, there is something fishy with the auto-clocking feature AMD has, not that it's a bad thing, but it might have been poorly thought out. It might be worth looking into. If i had a CPU and board to test I would, but alas I'm broke like the rest of the world, so no toys for me for awhile.
I keep wondering if the OC problem isn't a MB issue really.
Amd confirmed it throttles at 95C now....but said to keep it around 75.. ATMINSIDE can confirm that.
I don't think it's that complicated, maybe a stepping revision could extend the frequency range a bit but from my experience with the 1700 there was a huge wall at 3.9GHz. I could easily run at 3.9 with 1.36v and low 50s during small FFT in P95. 3950 the voltage was up by .06v and 4.0 I was at 1.48v/ 70c p95 so a 100MHz boost for that chip took 0.12v to hump it over that "wall" Really sounds like a voltage limitation to me.
