I figured it out!!!
I finally figured out how to use BOTH networks at the same time(Win2k/WinXP/WinNT), The process is as follows:
1) Turn off DHCP on one of the two routers
2) Hook up a crossover cable between one port on each router
3) Assign a static IP(private IP addr) to the primary IP section of the TCP/IP stack, with the default gateway as the IP address of the Router that you will be using to access the internet
4) Enter the DNS server IP addresses of that ISP's info
5)Click on Advanced button and enter a 2nd IP address, the IP address that you will be using on the secondary network(private IP)
6) Enter the other Gateway address(2nd router's IP address)
7) Add NetBEUI Protocol to the Stack( If you want to be able to share Files and folders on the network) If not, you will not be able to see the shares, and this should be added to each of the machines on your network
8) NOW this is OPTIONAL, cause as of now you will ONLY be able to use the Internet connection of one of the Two ISP's( Cable or DSL) You can install a program called NetSwitcher, available here:
http://www.netswitcher.com , this will allow you to save this configuration so that say you want to use the other ISP that you have, you can create another configuration with that ISP's info. After you save the original configuration using the utility in Netswitcher, you will create another one, but the information on the primary IP address will be the info on the other ISP's info( IP address of the private one from the other router as your primary IP address, that gateway address, the other ISP's DNS server info, on the advanced tab, you would enter the information of the other Network's router info(IP address, Gateway Address ), then you would be able to change to that ISP on the fly and still accessing the other network shares, printers etc.
If you need help setting this up, just ask, it took me a little while to figure it out, I posted some screenshots that may help you figure this out.
Jim
