- Mar 7, 2002
- Fremont, CA
Hi all,
For fitting reason I need to reverse fan rotation with my 120mm case fans. I tried to switch the red and black color wire and thought it would work. After I did that, the fan didnt rotate at all. I thought I burned the motor and then I switched the wires back to original position (red in the middle and black on the side) and it start rotating again.
I am confused because I thought reverse the + and - wires should make the motor (fan) rotation reversed. Unless fan manufacturer put some protection circuit to make motor only rotate one direction.
I would really appreciate any advise!!
Epox 8k3a+ (rev. 1.2)
AMD 2000XP
Corsair XMS3000 -- 199 @ 2-2-2-5-1
Kingmax PC2700 -- 180 @ 2-2-2-5-1
TwinMos PC2700 (Windbond chip stamping A version) -- fail @ 2-2-2-5-1
Samsung PC2700 (ATP designed; still waiting for Samsung original) -- 201 @ 2-2-2-5-1
CoolerMaster ATC210 modified with 8 fans
Thermalright AX-7 with Delta 80CFM
PC mods rheobus 4 channel fan controller (17W per channel)
digiDoc5 for temp hardware monitoring
2 x IBM ATA 100 HD
Toshiba 16x DVD and Pelxter CD-ROM
MV99
AMD 2000XP
2 x IBM ATA 100 HD
MV99
