Go Back   Overclockers Forums > Hardware > Cooling > Water Cooling > White Water vs RBX vs Cascade - prelim @ Procooling
Reply
Thread Tools
Old 01-28-04, 04:06 PM   #1
Cathar
Senior Member
Cathar's Avatar
White Water vs RBX vs Cascade - prelim results @ Procooling
There's a full review to follow, but Phaestus @ Procooling has posted some preliminary results here:
http://forums.procooling.com/vbb/sho...39&postcount=8
Test CPU load was a T'Bred B @ 2200MHz/1.81v running BurnK7. Hotter CPU's will yield larger differences.
Full review, along with the documented test procedure, which is very good through a lot of good equipment and assistance from BillA and others, should be coming at the Procooling front page in the next week.
Cathar is offline   Reply With Quote
Old 01-28-04, 04:17 PM   #2
Joe Camel
Senior Camel Kicker
Joe Camel's Avatar
THANK YOU!!!!!!!!!!!!!!!!!!
PS. Cather, any TEC WB thoughts? (former Dtec WW user)
__________________
-->> Help US fight: CANCER, Alzheimer's, Parkinson's & MORE with YOUR computer <<--
Joe Camel is FOLDing for Team 32 with 100+ GHz!
R.I.P pete_scout I wish we could have FOLDed a cure, for you.
HEAT
"So you see, it's not at all pointless, you just have to look for a different point" ... hafa 5/17/04
6800 EX Conroe @ 4740 MHz (395 x 12) - - Dry-Ice in The Camel Pipe -
- X1900 CrossFire @ 846/945 - - MachII Slave, D-Ice Master -
- 2x gig Corsair XMS 6400 CAS3 @ 494 MHz 4-4-3-1 -
- ASUS P5W-DH - - 700w "Mr Zippy" PSU
Joe Camel is offline   Reply With Quote
Old 01-28-04, 04:21 PM   #3
felinusz
Senior Overclocking Magus
felinusz's Avatar
Location: Toronto, Canada Computer: Finally Street Legal
Send a message via AIM to felinusz Send a message via MSN to felinusz
Finally a comparison of the three.
Very interesting info is blatently shown on the graph so far, I'm really looking forward to reading the entire coverage article!
Quote:
posted by pHaestus on the Pro/Forums
Note (a) the excellent performance of Cascade throughout (b) the poor low flow performance of the RBX (c) the crossover point around 2.25GPM where the RBX (essentially a modified whitewater) finally performs better than the standard whitewater. Most users don't have pumps like mine and so relative performance would be Cascade>Whitewater>RBX.
__________________
Intel Core 2 Duo E8400
eVGA 7600 GT
Shuttle XPC SD30G2 Plus
2x1024 Megabytes Kingston KVR800D2N5K2
36 Gigabyte Western Digital Raptor
500 Gigabyte Seagate Barracuda 7200.10 3.AAK
How Overvolting Works, The Dangers of Overvolting, and "Safe" Overvolting Technique
Guidelines for Thorough Stability Testing ~ My Heatware Feedback
felinusz is offline   Reply With Quote
Old 01-28-04, 04:25 PM   #4
crimedog
crimedog's Avatar
Send a message via AIM to crimedog Send a message via MSN to crimedog Send a message via Yahoo to crimedog
glad i have a mag3
__________________
930 & P5WD2 (vcore + droop, mch vdd, ddr2 vdd)
7900gto 720/1680
2x300gb samsung spinpoint sata2 in raid0
I love to volt mod
i'm packing heat
crimedog is offline   Reply With Quote
Old 01-28-04, 04:28 PM   #5
Joe Camel
Senior Camel Kicker
Joe Camel's Avatar
i wonder what plate # was used in the RBX for this test....
__________________
HEAT
Old 01-28-04, 05:46 PM   #6
nikhsub1
Mostly Useless Moderator
nikhsub1's Avatar
Send a message via AIM to nikhsub1
And my suspicions have been verified. pHaestus is the man, and has possibly the best test bench other than BillA. Now I need to see the original WW vs. the D-Tek.
__________________
*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
Q6600 @ 3.6Ghz / Asus Maximum Forumula X38 / 4GB Crucial Ballistix 8500 / X1950XTX
PC Power & Cooling 750W Silencer
Mountain Mods U2-UFO Cube
Storm G5 --> MCW30 --> MCW60 --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
XP 64 FTW
"Artificial intelligence is no match for natural stupidity."
nikhsub1 is online now   Reply With Quote
Old 01-28-04, 06:58 PM   #7
crimedog
crimedog's Avatar
what's the GPH of a "typical" system (with one of these rather restrictive blocks in it).
Like mine for example!
__________________
7900gto 720/1680
I love to volt mod
i'm packing heat
Old 01-28-04, 07:03 PM   #8
pauldenton
Hmm: given that the Whitewater is less restrictive than the Cascade, which aiirc is less restrictive than the RBX?? - then presumably the "true" crossover must be higher still, since a system that'd do 2.25GPM through an RBX would do more than 2.25GPM through a whitewater.....
can't wait for this....
pauldenton is offline   Reply With Quote
Old 01-28-04, 07:46 PM   #9
nikhsub1
nikhsub1's Avatar
With the mag 3, a heater core and the RBX I would imagine you would be somewhere around 7.5 - 8lpm or 1.8GPH or so.
__________________
XP 64 FTW
Old 01-28-04, 07:51 PM   #10
Cathar
Senior Member
Cathar's Avatar
At 1GPM, the pressure-drop for each block is:
Cascade: 1.02PSI
White Water: 0.67PSI
RBX #1 Nozzle: 0.59PSI
With an Eheim 1048 and a DTek Pro core, I estimate around:
Cascade: 1.15GPM
White Water: 1.3GPM
RBX #1: 1.35GPM
With an Eheim 1250 and DTek Pro core, I estimate around:
Cascade: 1.55GPM
White Water: 1.75GPM
RBX #1: 1.83GPM
With a Mag 3 and a DTek Pro core, I estimate around:
Cascade: 1.75GPM
White Water: 2.0GPM
RBX #1: 2.1GPM
Old 01-28-04, 07:52 PM   #11
Cathar
Senior Member
Cathar's Avatar
Quote:
You had the LPM right. 8LPM = 2.11GPM
1 (US) GPM = 3.785LPM
Old 01-28-04, 07:54 PM   #12
Voodoo Rufus
Browncoat Moderator
Voodoo Rufus's Avatar
Hmm, they all have nice results, as expected.
Nice to see performance graphs of them finally.
__________________
"I am a leaf on the wind, watch how I soar!"
Serious Gamers Halo Custom Edition
Green Leaves!
Voodoo Rufus is offline   Reply With Quote
Old 01-28-04, 08:36 PM   #13
Biglipzits
Send a message via AIM to Biglipzits Send a message via Yahoo to Biglipzits
Wow cathar i would neer have thought that the cascade and WW would be more restrictive than the RBX.. So is it really just the thin design in the block that makes it require more GPH to perform as well as a WW? And was there any difference between your WW and Dteks own now?? When you said the cascade was 1 degree cooler than the WW was it your own or Dteks and if your WW performs better what really is the reason for that??? I always had confidence in the WW over the RBX and these results prove that i made the right choice. cathar your the man
Biglipzits is offline   Reply With Quote
Old 01-28-04, 09:08 PM   #14
squeakygeek
squeakygeek's Avatar
Send a message via AIM to squeakygeek Send a message via Yahoo to squeakygeek
Quote:
The cascade and whitewater ARE more restrictive than the RBX:
Cascade: 1.02PSI
Cascade: 1.15GPM
White Water: 1.3GPM
RBX #1: 1.35GPM
Cascade: 1.55GPM
RBX #1: 1.83GPM
Cascade: 1.75GPM
White Water: 2.0GPM
RBX #1: 2.1GPM
and welcome to the forums!
__________________
Barton 2500+ @ 9.5 x 230 (would do 10x if my mobo wasn't retarded)
Epox 8RDA+ rev 1.1 A1 stepping w/ Vdd mod
ATI Radeon 9500 pro, 390/315
512mb Buffalotech PC3200 (BH-5 Winbond Modules) @ 230mhz, 2.5 3 3 7, 2.9v
FSP-550; 550 watt Sparkle PSU
raid lvl 0: 2x 80gb 8mb cache Diamondmax 7200 rpm
52x 24x 52x Lite-On CDRW
soon to be watercooled (memory, vga mem, gpu, NB, cpu/peltier)
squeakygeek is offline   Reply With Quote
Old 01-28-04, 09:15 PM   #15
johan851
Senior Member
johan851's Avatar
Looks interesting. Nice to have a good performance review on those blocks! Cathar, the flow restriction stuff for the RBX you provided are using nozzle #1 - does that mean the review is using nozzle #1 as well? Also, will the full review have different RBX nozzles?
__________________
Asus P5K-Deluxe WiFi | Intel Q9400 | 2x2GB GSkill PC6400 | Radeon HD 4670
60GB OCZ Agility | 2x 1.5TB Samsung F2 in RAID 1
AV-710 --> Zhaolu DAC 1.3 --> Custom M^3 --> Custom LM3875 ChipAmp --> Modula MTs
Dual Dell 2007WFP's | Watercooled
johan851 is offline   Reply With Quote
Old 01-28-04, 09:41 PM   #16
pauldenton
Quote:
Cascade: 1.75GPM
White Water: 2.0GPM
RBX #1: 2.1GPM
so my previous guess about the RBX was wrong then - looking at the points on the graph it looks as if that Mag 3 might be about the crossover (esp as presumably the procore would be slightly better at 2.1GPM than 2GPM)
wonder what kind of flow an MCP600 + pro core would give?
Old 01-28-04, 09:48 PM   #17
calvin
calvin's Avatar
Without identifying nozzle used on RBX the data loses relevance. Also I have to question why only a single rbx curve given the range of nozzle options available with this block? This aspect by itself can call objectivity into question.
In no way defending RBX or suggesting something amiss in the data or intent of the investigator. Just that these results as presented raise additional questions. Perhaps the full review addresses all these points in which case these comments can be taken as premature.
The fact BurnK7 employed is a good sign though, so will wait with interest on full review.
__________________
ASUS A8N32SLI Deluxe
Opteron 170@3.0 ghz, wc'd
Memory: Shikatronics
8800GTS, wc'd
Case: Chenbro SR107
Rad: Thermochill PA120.3
calvin is offline   Reply With Quote
Old 01-28-04, 09:51 PM   #18
nikhsub1
nikhsub1's Avatar
ha! even for a yank I know my lpm's better than my GPM's!
__________________
XP 64 FTW
Old 01-28-04, 09:58 PM   #19
Cathar
Senior Member
Cathar's Avatar
Quote:
I don't know.
Quote:
Yep, a Mag3 would give about the same performance between the White Water and RBX, so long as there were no additional blocks in the system.
I estimate:
Cascade: 1.6GPM
RBX #1: 1.8GPM
Old 01-28-04, 10:05 PM   #20
pauldenton
iirc #1 is the nozzle that comes as standard? some stores (at least in here in the UK) don't even stock the others....
Old 01-28-04, 10:10 PM   #21
pauldenton
I estimate:
Cascade: 1.6GPM
RBX #1: 1.8GPM
hmm - either these of the 1250 one must be out...
Cascade: 1.55GPM
RBX #1: 1.83GPM
Old 01-28-04, 10:14 PM   #22
Cathar
Senior Member
Cathar's Avatar
...and as a further indication of how high-head pumps could really care less about the block's restrictiveness (within reason):
Iwaki MD20-RZ (US spec 60Hz) + DTek Pro Core.
Cascade: 2.35GPM
White Water: 2.56GPM
RBX #1: 2.61GPM
Old 01-28-04, 10:17 PM   #23
Cathar
Senior Member
Cathar's Avatar
The 1250 + Cascade would be more like 1.50GPM upon reviewing the curves. The rest of the data points look to be fairly good. Trying to maintain consistency between GPM and the LPM on the graphs I'm looking at, and expressing them to the closest 0.05GPM.
Take my values as ±0.1GPM in any event.
Old 01-28-04, 10:29 PM   #24
vonkaar
vonkaar's Avatar
Beautiful... 'finally' is all I'm thinking at the review... finally a 'trusted' source compares the 'top' blocks. Awesome.
__________________
-->>Ranked #1 of all folders in the world!!<<-- named Vonkaar...
I7 920 D0 @ 4.2Ghz // MSI X58 Pro-E // Sapphire 5870 // 6x Seagates in RAID0 // Microsoft Keyboard Overclocked to 18 WPM (STOCK COOLING!)
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittamj
vonkaar is offline   Reply With Quote
Old 01-28-04, 10:30 PM   #25
pauldenton
and the whitewater? (getting a cascade not being an option atm...)
why do i always leave things too late )
Old 01-29-04, 01:40 AM   #26
Home-Chicken
Send a message via AIM to Home-Chicken
DOH! Is my cascade being underpowered by my Danner Mag 2?
Home-Chicken is offline   Reply With Quote
Old 01-29-04, 03:58 AM   #27
Cathar
Senior Member
Cathar's Avatar
Quote:
Hmmm. Predict around 1.35GPM with the Cascade, Mag2 and a heater-core.
Looking a Pheastus' graph, that puts the Cascade still ahead or equal to either the RBX or White Water, no matter what pump you stick on them. Factoring in the extra pump heat to push those blocks to perform at their best, and the Cascade would still be in front.
Old 01-29-04, 06:25 AM   #28
xsmid4
what kind of flow you estimate with Eheim 1046?
xsmid4 is offline   Reply With Quote
Old 01-29-04, 06:45 AM   #29
Cathar
Senior Member
Cathar's Avatar
Quote:
Using a low-restriction radiator (DTek Pro), roughly:
Cascade: 0.9GPM
White Water: 1.0GPM
RBX #1: 1.05GPM
Old 01-29-04, 09:31 AM   #30
DayUSeX
DayUSeX's Avatar
wow that was probaly one of the most usefull reviews ever, how cool. ALl the "high" end blocks dueling it out, though i still love my maze 4 xeons.
STill good to see a clear graph.
__________________
2x Xeons HT 3.23ghz load 29C
4gb Dual Channel CAS 1.5!!!! BH5
2x 80gb WD 8mb HD 2x 250gb WD 8MB
Plextor 42x CDRW NEC 4x DVD+-R DL
NV40 Quadro Comming Soon!! Audigy 2 ZS
DayUSeX is offline   Reply With Quote
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
