mynameisyeo32
- Aug 6, 2012
I was wondering if I could paint my ram heatsink.
TIA
TIA
I don't see why not. To tell the truth RAM heatsinks are more decorative than funtional anyway.
I've generally found that removing the RAM sinks altogether helps with stabillity..... They're just there for bling.
A lot of the heatspreaders are made out of steel. Steel is a terrible thing to use for heatsinks. The ram may well be running hotter with the steel heatspreader than without.
If the heatspreaders are aluminum or copper, they'll probably help.
That said, they haven't been needed since the end of the D9 era (new D9s don't count).
^^^ Thats certainly not been my experience. I've had a few modules where higher clocks were possible without the heatspreader. Likewise I've had others where is seems to make no difference though I have found then to occasionally have a negative impact when overclocking.
Having said that, the only thing I take into consideration is a given modules potential for running a certain speed, and if it does have heat spreaders, how tall they are.
Are you trying to be offensive?
I can't remember if it was OCZ gold, ST chrome or both, but I picked 'em up with a magnet on accident.
I'm well aware that steel is a lousy heatsink material, as my post states. For reference, aluminum conducts heat about 5.6 times better than steel does at room temperature.
If you're going to start calling for evidence you need to give some too, let's see a link to testing on DDR3 heatspreaders vs no heatspreaders.
From a thermodynamics standpoint, a good heatspreader and convective cooling will keep the ram cooler than convective cooling with just the ram chips.
A functional heatspreader will not heat up as much as the ram chips under it would if left bare, that statement is false.
A heatspreader becomes a liability if it cannot conduct the heat away from the ram chips into itself.
