Not entirely satisfied.. so here goes.
Specs ->
14" x 14" x 14" cube shape
3/4" plywood bottom and sides, 1/2" plywood top, back and front
Tolex leather covering
3x120mm inlet fans
3x120mm top exhaust fans
2x140mm inlet side fans
subtle blue led lighting
PWM fan controller
1/2" rubber standoffs
brushed stainless steel side handles
brushed stainless fan grills (note, I just used a simple wire mesh look for the image)
Will probably use some sort of conduit system for wire management, thinking black PVC or something of that nature.
2 tier system, PSU and Hard drive cage on bottom, MOBO on top.
MOBO will be on a slide out tray for accessibility reasons
So, I don't feel like going balls out on a rendering, so heres some simple MS Paint action for ya.
Yeah, looks tacky here. But its going to come out very similarly to the last amplifier I made, which came out very well.
Will go slow, will get the wood bits this week, and start putting together that. When Im satisfied with that, I will purchase the electronic bits.
Specs ->
3x120mm inlet fans
PWM fan controller
