ray99mond said:Hi, i dun plan to do any mod
and i found tat AI7 only have max vcore up to 1.9v..
any board can get 3.2vdimm and over 2.0vcore ??
* i am amd user, as i know amd can go for more vcore like over 2.0v
how about intel ? coz usually i only c 1.7vcore for oc only...can go higher ??
thanks for that ....coz i am planning to get a phase coolingCid said:The rule of thumb around here seems to be to give the P4 no more than 1.675v vcore and this without a doubt shouldn't even done with air if your going to.
Reason being is that you seriously run in danger of S.N.D.S (Sudden Northwood Death Syndrome). P4's are not like A64 in terms of vcore. The range for OCing a P4 is generally 1.5~1.675.
ray99mond said:how about DFI INFINITY ???
Rio71 said:i have
2 x p4p800 (dlx)
2 x ic7
1 x is7-e
the best one ist is7-e. (unmodded, and modded tooooooo)
is7-e have the cleanest vcore but ic7 come close.
on is7-e always pat can set.
ic7 cant pat with 4 x ram is installed...
i dont know about ai7, but i know with prescott its the poorest choice.
