- Nov 14, 2009
- Pleven, Bulgaria
So.. you want to join overclockers.com's benching team, but just can't meet the requirements?
Your hardware is old?
You're not familliar with the requirements?
You have no idea what HWBot is all about?
I'm here to change that.
There's nothing to worry about, we've all been there.
So.. lets start with the guide, shall we?
Things you'll need:
What is a HWBot and how can I submit my scores to it?
- HWBot.org, main office located in Belgium, is a dynamic team of international hardware fanatics as well as internationally recognized overclockers, dedicated to gathering specifications and benchmark performance results of computer hardware as well as serving a non-stop overclocking competition platform for amateur and die-hard overclockers..... click here to continue reading
How are hardware points being calculated?
- Points are awarded based on hardware popularity, more submissions with the specific CPU/GPU/Motherboard = more boints.
Please bare in mind that this doesn't apply in all cases. For instance - if you're ranked 9999th out of 9999 submissions with the specific hardware you will most likely earn 0-0,1 points, which is less than if you were the only one using this component.
Practical example:
I'm the only one using Phenom II X4 850 so a single submission got me 7 points, whereas my E5400, which is more popular only received 0,1.
Types of benchmarks:
You can click on a category to view the full list of benchmarking software available for it.
Submitting your score(s):
Step 1: Create a new HWBot account
An example of how the registration form should be filled correctly:
Step 2: Click the "Submit" button located at the right corner of the webpage
Step 3: Select the benchmark you want to submit (for instance SuperPi 32M)
Step 4 fill all the necessary fields (check at the end of the topic for a full list)
Click submit and its all done! Congratulations on making your first HWBot submission!
My score is too low, thus I can't achieve the required 20 point limit to join, how can I overcome my hardware's limitations?
- You can do this by overclocking your components.
What do you mean by "overclocking"..? What does that mean?"
- Overclocking is the process of making a computer or component operate faster than specified by the manufacturer by modifying system parameters.... click here to continue reading.
Guides on overclocking/useful tools/articles
Intel
3 Step Guide To Overclock Your Core i3, i5, or i7 - Miahallen
HOWTO: Overclock C2Q (Quads) and C2D (Duals) - A Guide v1.1 - graysky
AMD
Dolk's Guide to the Phenom II - Dolk
OC'ing an AM2: An update to Easy 1, 2, 3, Overclocking ... - QuietIce
Software:
CPU-Z - shows CPU frequency, memory info & etc.
GPU-Z - shows graphics card clocks, info & temperatures.
SetFSB - for squeezing those last few mhz out of your CPU (NOT RECOMMENDED FOR PEOPLE NEW TO OVERCLOCKING
AMD OverDrive - AMD CPU overclock on the go
HWMonitor - component temperature/voltage monitoring at its finest.
RivaTuner - graphics card overclocking software.
Benchmark Buffet - lots of useful info
P.S Please bare in mind that BIOS overclocking is always recommended over using OC software.
Extra stuff
Necessary fields:
CPU:
SuperPi, PiFast, SuperPi 32M,PCMark 04-05, CPU Frequency, wPrime 32M/1024M, PCMark Vantage, UCBench, PCMark7 - benchmark score, processor & verification screenshot
Disk:
AS SSD benchmark - score, processor, disk manufacturer & verification screenshot
Videocard:
3DMark 99-11, vantage - score, processor, videocard & image verification screenshot (orb link required for top 20 hall of fame)
Aquamark & Unigine - processor, videocard & .hwbot file
Motherboard:
Reference clock - benchmark score, processor, motherboard model & verification screenshot (cpu-z link required for top 20 hall of fame)
Memory:
MaxxMem & Memory clock - score, processor, memory & verification screenshot
I've only linked a small part of the benchmarks, since most of them are submitted via http://hwbot.org/submit/create
Benchmark specific rules:
Memory:
Motherboard:
Processor:
Source(s):
http://hwbot.org
http://google.com
http://wikipedia.org
Thanks to Dolk, Miahallen, QuietIce and graysky for their wonderful overclocking tutorials!
Also - a special shout out and a huge thank you to everyone from our benchmarking team.
Thanks for all the guidance, support and the awesomness you guys are spreading around.
Things you'll need:
- A computer
- Some spare time
- Dedication
Practical example:
Intel
AMD
Software:
Extra stuff
Necessary fields:
CPU:
Disk:
Videocard:
Motherboard:
Memory:
Memory:
Motherboard:
Processor:
- SuperPi 1M/32M
- PiFast
- PCMark 2004
- PCMark 2005
[*]CPU-Z (CPU Frequency) - wPrime 32/1024M
[*]PCMark Vantage - UCBench 2001
- 3DMark 01 SE
- 3DMark 03
- 3DMark 05
- Aquamark
- 3DMark 06
- 3DMark Vantage - Performance
- 3DMark Vantage - Xtreme (DX11)
- 3DMark Vantage - Basic (DX9)
- 3DMark 2000
- 3DMark 99 Max
Source(s):
http://hwbot.org
http://google.com
