- Jan 19, 2014
- holland
Hello guys, and maby girls.
I have a little quastion, atleast i hope its a little one.
Sinds a week a have a older cpu/socket in my pc, the i7 975 extreme on a asus p6t deluxe v2 mobo.
I,m not a compleet newbie at overclocking but my experiance is on ivy and sandybrige, so 1366 socket is new for my.
I overclocked this cpu before till 4.0ghz just true the multiplier, but after some reading in english what is not my best language, i overclocked it to 4.1 but this time by raising the bclk.
so i whant love to now are the settings oke that i did, or do you have some advice for my.
This are the settings i did in the bios, what i don,t write down is on auto or default settings.
my mem is acording the specs 1600mhz 7-7-7-20 1.65v
but as i give that in then it dont work.
A.I overclock tuner manual.
cpu ratio 21.
bclk 195
speedstep/turbo/cpu spread spectrum/cie state all disabled.
dram freq 1563mhz.
uclk 3127mhz.
qpi link data 7038mt/s
cpu vcore 1.3125.
cpu pll 1.88
qpi/dram core voltage 1.31875
llc auto
cpu different amp is left on auto.
Thats it, i did run a prime95 test for 30 minutes and the highest temp was 74 degrees.
IS THIS OKE.
tips are very welkom.
O and i,m on air, my cooler is a thermalright silver Arrow, and my case the cooler master haf X
cpu ratio 21.
bclk 195
dram freq 1563mhz.
uclk 3127mhz.
cpu vcore 1.3125.
cpu pll 1.88
llc auto
IS THIS OKE.
