- Dec 19, 2000
- Stockton Cal, USA, Earth
Ok, since I built this machine, I have been trying out just about any linux distro that will boot from a live session without using safe mode and not having much luck....most of the time it will start to boot, and the screen will go black never to show anything until I reboot to my main OS (Mint16 KDE 64) or boot the live session in safe mode
In my main OS I decided to try to look at the logs and found this :
06/19/14 01:44:49 PM rod-desktop kernel [ 0.600376] video: module verification failed: signature and/or required key missing - tainting kernel
Is this what is causing me to not be able to us my system to it's full potential?
When I look in Kinfocenter, I see the graphical info> openGl the value of the display is 0: the value of the direct rendering shows no value just an arrow pointing to the driver...next is 3d accelerator: value is unknown
Next is driver Vendor: VMware inc.
renderer: Gallium 0.4 on livmpipe (LLVM 3.3, 128 bits
That's all it shows under openGL.
I have a few other errors mostly to do with Bluetooth an two that seem to be critical as follows:
GLib-GIO-CRITICAL: g_file_info_get_attribute_uint64: assertion 'G_IS_FILE_INFO (info)' failed
I should also point out that I'm using a Sansui 19" wide screen tv for video through the vga port on the TV
Asrock H61M-VG3 soc 1155> Intel G2030 @3.0ghz with Onboard Intel HD graphics enabled> (no video card yet which is my main prob) Supertalent DDR3 not sure the speed. and a 500gb serial ata hdd and generic dvd burner
On a lighter note: I now have plenty of Live distro's on CD and DVD to show people who want to migrate to Linux
Thanks for any and all suggestions,
Doc
Doc
