- May 1, 2003
- Phoenix, AZ
Hello All
I have had this problem periodically (2-3xs a year) but I'm looking for some fundamental answers first.
I have 4(four) AC-66Us but ONLY ONE is the AP. The rest are obviously wirelessly bridged. Yes they ARE using DD-WRT and I do understand many of the DD-WrT features. I come on bended knee now because of frustration and I could always be missing something. This is really NOT about DD-Wrt, although I could be missing a setting (I'll go to their forum about possible settings though) this is more about why I periodically get IP conflicts by seemingly only one of the routers but the entire network loses connectivity see below:
Setup goes like this:
AP =Blue
Client Bridge 1 =Red
Client Bridge 2= Purp
Client Bridge 3 =Orange
Red has 3 wired clients
Purp has 4 wired clients
Orange has 2 wired clients
Purp is the NEWEST of the four and all Wireless client bridges are running the same version of DD-WrT
The important part is this: I have the DHCP set on Blue. I have ALL THE WIRELESS CLIENTS with static IPs (it requires MAC addresses anyway) on Blue through the DHCP. Since the AC-66U is a dual band router I DO have Blue running both bands but ONLY Purp has Both Bands connected as a bridge
The MAIN connection is Red (Man Cave w/3 wired clients) and Blue (AP) this is where the heaviest traffic comes from. Purp was originally the AP but decided to make it a client AND IT IS THE CULPRIT with causing problems (it is functional and passed all the testing I did with it so I don't think it's a bad router). this was happening with the DIR-825 I USED to have before it was donated and replaced (it worked and is still working at my folks house).
The main issue is that whenever Purp is powered on and it attempts to connect it causes IP conflicts and essentially causes my entire wireless network to lose connectivity. I have looked and re-looked set and reset the settings and double checked x4s that it is set to Client Bridge with the appropriate Password and settings (AES on all) My settings are correct on ALL the Bridges. There are LONG stretches of time where everything HAS WORKED as it should. But I just recently had a power outage at my home which I had to reboot my settings on Blue. Thus the conflicts began again and I am now at my wits end as to why this is not working as it was. I had thought I had nipped this with the DIR-825 but I am missing something fundamental and thus I require assistance
So the question becomes why?
Do I need to have EVERY client (wired as well) have an IP/MAC set on Blue?
Why is it ONLY Purp that is seemingly causing the issue?
I DO have a PS3 AND Xbox but I had THOUGHT I had turned each wireless setting OFF
Could there be another wireless client that is attempting to connect that is throwing the DHCP off
IF I was to MAC filter perhaps then the issue would resolve?
Please advise and Thanks in advance
AP =Blue
