M Mazspeed New Member Joined Mar 29, 2001 Sep 1, 2001 #1 I have an overclocked 866 socket 370 p3 but I was wondering what is the fastest p3 Chip I can put in this board? Thanks in Advance Cheers Mike
Phil Senior Member Joined Jan 13, 2001 Location Bolton, UK Sep 1, 2001 #2 I'm not sure if it will support the new cDO stepping, if it does then the best you can get is 1.1ghz, if it doesn't then the best is a 1ghz cCO
OP M Mazspeed New Member Joined Mar 29, 2001 Sep 2, 2001 Thread Starter #3 Will I be able to over clock the 1 gh chip then? Thanks for the reply Cheers Mike
Phil Senior Member Joined Jan 13, 2001 Location Bolton, UK Sep 2, 2001 #4 yes as long as you have the bus options and preferabally voltage options as well. Most 1ghz cCO chips get to 1.1ghz without too much bother.
