- Jul 15, 2008
- Suffield, Connecticut
Stack Attack
First off, to my first *official* build log, a project titled Stack Attack.
I've been doing small mods on my cases for about 2 years now. I started in the summer of 08 with a custom window and paint job, and have been working my way up since then. When I first started out, I had a pair of tin snips and some spray paint. I've now got a full machine shop I can use, with such tools as a chop saw, band saw, lathe, Bridgeport mill, belt sanders, and a plethora of hand tools, so we may be doing some custom fabrication this time around
Case
The case we'll be modding is the tried and true Cooler Master Stacker 832. An all aluminum full tower blast from the past.
The case will be painted gloss white on the exterior, with a matte black interior. The fans will all have blue LEDs.
Parts List
Plan of Attack
And that's all I've got planned for the moment
Once all of the parts arrive this week, I may tinker with a few other ideas and mods on the case. I will provide pics and updates as I start the work. What do you guys think?
Case
Parts List
Cooler Master Stacker 832 refurb - $50 from CM - Received
Cooler Master R4 Blue LED fans - $8 each (11 total) - Received
Cooler Master 4 in 3 SATA cage refurb - $10 from CM (3 total) - Received
Apevia Black steel fan grills - $1 each (11 total) - Received
Custom 12 switch fan controller - $20 from OCF Member - Received
Powder Coating - $80 from local shop - Need to schedule
Plan of Attack
Strip down case for powder coating
Paint fans matte black (currently clear plastic)
Send case, panels, and accessories to powder coater
Receive parts back
Sleeve all fan and case wires
Make any fan cable extensions and sleeve
Install all fans, drive cages, fan controller
Sleeve PSU
Install hardware
