Hello everyone,
I am building a new PC and I really want to create a single loop water cooling system to cool it. I have a Corsair Obsidian 900D case so I have plenty of room to house the components.
The PC components are as follows:
Asus Rampage IV Extreme x79 Motherboard
Intel i7-4820k CPU
16gb Quad Channel Memory
Radeon 7970 3gb CPU
500gb Samsung 840 Evo SSD
3tb Regular Hard Drive
Asus Xonar Essence STX Sound Card
Okay, I am thinking of buying the following components:
1. Koolance CPU-380i CPU Water Block
2. ATI Radeon 7970 Water Block (not decided which brand)
3. Swiftech MCP350 Pump and MCP35x Reservoir
4. Alphacool Nexxxos Full Copper Triple Fan Radiator
Thats basically it so far. I am trying to buy used to keep the total price down. I am wondering if anyone suggests that I get a waterblock for the chipset? Would that be necessary or would i be a waste of time?
I really am confused about the fittings, tubing and coolant I need to connect all the parts into a complete system.
What would you suggest?
Thanks for the help.
Intel i7-4820k CPU
Radeon 7970 3gb CPU
