A couple months ago, I replaced my Radeon 6850 with a R9 290. With the R9 290 installed, my system would very frequently just hang and require a hard reset (usually within 1 hour of use). Nothing was overclocked, and I have been using the same system with the 6850 for years with no problems.
So, I started messing around in the BIOS, and I found that when I changed the PCI-E clock rate to 150 MHZ, the system ran perfectly. I have been running it this way for about a month now with no problems. Anyone have any idea what's going on?
I just tried to read up on it, and all I found were some forum posts. I guess some extreme overclocks can be stabilized by changing the PCI-E clock. Why is this? Some posts also stated that you shouldn't really go above 110 MHZ, and that anything above 130 MHZ is "dangerous." What do they mean by "dangerous?" I don't really know anything about overclocking, but I thought only changing voltages could harm components?
