I'm completely ignorant to programming and have been given the task to develop/find assistance to develop a program that does the following.
Goal: Mini Computer with 4x USB ports needs to transfer files (small video files and mp3s) to a specific USB port when plugged in. 2x of the USB ports will be designated to transfer out Video files when a flashdrive is plugged in. The other 2x USB ports will be designated to transfer out anMP3 file when a flashdrive is plugged in. This is going to be consumers use so the easier the steps they have to take the better.
Parameters:
-Each USB port will be uniquely named. Ex. If flashdrive is plugged into USBPort1 or USBPort2, MP3 will be transferred. If flashdrive is plugged into USBPort3 or USBPort4, Video file will be transferred.
-Should be able to handle plugging in multiple flashdrives at a time. If flashdrives are plugged into all ports at the same time, the appropriate file will be transferred to the designated port.
-USB Ports should be listening for a device to be plugged in.
-Check USB flashdrive for space. Will the Video or MP3 file fit?
-If Yes, copy the latest file in C:\X-directory to flashdrive
-If No, either (optional- notify user not enough space) or eject device and go back to listening for new USB device to be plugged in
(Optional) - Notification of when file is finished transferring to flashdrive, if flashdrive is too full, or generic error from failure (Maybe by LED? to Monitor?)
Does anyone know how I can do this? Or where I can find help to create a program like this? Or is there a hardware device that I could use that would make this work? I've never had to find help to create a program before and this is a very niche project. To my knowledge there are no programs that match our needs available right now.
Parameters:
