- Oct 9, 2001
- Dundalk, Ireland
Hey all.
I introduced the first HDA Mystique 7.1 thread to this forum over 6 months ago and i've seen a few threads since regarding the card.
So I thought i'd start a thread regarding all aspects of the HDA card.
For the folks that don't know about this sound card, it is the first PCI based sound card that supports Dolby Digital Live, which encodes any (preferably stereo) source into Dolby Digital in real time.
It uses the C-Media CMI8768/PCI-8ch+ PCI chipset, which introduces 8 channel audio with Dolby Digital Live Real-Time Contents Encoder.
I just got my card a week ago and am very satisified with it.
Here are the obligatory pics of which we are all familiar with now:
My observations:
First off, as soon as you get the card, download the new drivers from www.hidiaudio.com. These offer better definition and seperation in the sound, as well as a few fixes. I found that there is more sound produced by the center channel with the new drivers and overall sounds a lot better.
I am using Cambridge Soundworks 5.1 digital speakers and have my external amplifier set to decode the Dolby Digital signal that I have passing through the SPDIF on the HDA Mystique.
Because the signal is passed through, there are no options to adjust bass or treble, so it is important to have a decent external amplifier which all you to adjust these settings. I am using a homebuilt 250w RMS subwoofer with the amplifier so I can adjust my bass level, crossover and phase so i'm set.
However I have heard numerous people saying that the bass ouput on the first set of drivers was far to high, I found the opposite, in that the bass level was quite low. With the driver update, I found the bass level increased slightly and was more defined. I dunno, could be just my setup.
I noticed another thing with this card, and it seems to be a glaring omission on Hitecs part. Any analogue INPUT source on my card, connected through the standard 3.5mm line-in, WILL NOT encode into Dolby Digital. I have a standard Hauppauge TV card and its output connects to the soundcards line-in.
However it refuses to play through the SPDIF. And contrary to what others have been saying about the analogue outputs being disabled when the SPDIF is enabled, they are not. I found this out when I connected a standard 3.5mm to 3.5mm cable from the front analogue output on the HDA Mystique card to a 3.5mm analogue input on my amp. The TV card played through the amplifier, so the analogue outputs were obvously active, and at the same time, I was playing an MP3 through the SPDIF.
The fact that no line in source will be encoded to Dolby Digital is very annoying for me. It means I have to have a cable from my analogue outputs to my amp as well as the optical SPDIF cable. This means I have to swap out the analogue cable each time I want to use my headphones or to watch TV.
Anyone else have this problem?
Apart from that little niggle, I find the card an excellent buy, especially as i got it on special offer of £29.95.
The sound is exceptional and is a welcome upgrade from my Audigy Player of 3 years.
Any thoughts/additions on the card would be welcome.
My observations:
