- Oct 22, 2011
Oh well.I guess im out of options. Im trying to cool this darn cpu to max and i cant get temp down.I have AMD stock HSF(running at the speed of a b747) with temps of 51@ idle. Reapplied thermal no good.tried again no good.
I also have Artic Cooling Freezer 13 and reapplied and temp actually went 69@idle. Reapplied and reseated cooler like 4 times(same with stock hsf) and with the necessary amount of compound like artic cooling instructions states very clearly.
Temp never reach lower than 45@ Bios. I decided to return the arctic cooling freezer back for refund and get a better one.Stock HSF is unbareable running and hot as well.I even reduced Vcore to see if i get better temp and @ 1.2V(unbelivable) and still temp is right now at 52c in desktop
I have two options:
1.Return CPU to see if theres a problem with it(problably unlikely).
2.Get a new Cooler that meets the demands of the cpu.
I want someones advice on getting a new cooler for this darn cpu thats driving me crazy. Im willing to pay with one day shipping up to $100.
Any feedback would be appreciated.
Will order cooler today so i need would appreciate your feedback.
System Specs:
Gigabyte 990fxa-ud3
AMD FX-8120 stock speed
Corsair Vengeance 16GB(4 sticks) DDR3 1600mhz
1.5tb Hard drive 7200rpm
HD 6870X2 Dual GPU
Windows 7 64 bit
Case:Maxcube Vortex 3620 with 120mm fan front and back
PSU:1080W HEC Sli and CF certified
Coolers in my possesion:Freezer 13 and stock HSF.
Compound:Arctic Cooling MX-2
I have two options:
System Specs:
Gigabyte 990fxa-ud3
HD 6870X2 Dual GPU
Windows 7 64 bit
