- Jan 18, 2014
- South of Boston, Ma. USA
I'm planning my first custom loop. I've done a lot of research and believe I've got all the bases covered, but... I'm now reaching out to the experts. All advise and suggestions are appreciated.
This build has a heavy emphasis on aesthetics, but also needs to be functional.
The case will be a white Phanteks Enthoo Primo (once its released).
On order is an Asus rampage iv black motherboard, 64gb of Corsair Dominator Platinum memory sticks with light bar kits. And 2 GTX 780ti cards. And I'm off today to Microcenter to pick up a 4930K.
I'm planning 2 separate loops.
The CPU loop is XSPC D5 dual bay combo to an XSPC raystorm (already own both) to the thickest Alphacool 420 rad that will fit in the top then back to the res.
The GPU loop will be an XSPC a D5 photon res/pump combo (as long as it will fit) to a Alphacool 280 Monsta in the bottom to the thickest 240 that will fit in the front into parallel loops to XSPC razor GPU waterblocks back to the res.
All is going to be connected using rigid tubing painted to simulate either black chrome or a polished nickel finish. The will also be Aquacomputer USB flow meters in each loop. 1 in the CPU & 1 in each parallel GPU section. As well as provisions for draining each loop for maintenance.... Thoughts???
