Hello,
I posted on here a few weeks ago. i have never built a computer before and this is my first one. So far i have these parts
Case= Cooler Master HAF 922 Mid Tower ($118) there is one 120mm led fan and Two 200mm led fans http://www.newegg.com/Product/Product.aspx?Item=N82E16811119224&cm_re=haf_922-_-11-119-224-_-Product
Motherboard= ASUS M4A78T-E ( $139 ) http://www.newegg.com/Product/Product.aspx?Item=N82E16813131366
CPU=AMD Phenom II x4 965 3.4Ghz($165) http://www.newegg.com/Product/Produ...727&cm_re=phenom_ii_x4-_-19-103-727-_-Product
Optical Drive= Asus DRW-24B1st ($19) http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
RAM= G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) ($74) http://www.newegg.com/Product/Product.aspx?Item=N82E16820231276
Harddrive= Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" ($64) http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
OS= Windows 7 64bit ($99) http://www.newegg.com/Product/Produ...cm_re=windows_7_64_bit-_-32-116-754-_-Product
Graphics Card= hd 5850 ( havent bought yet but looks like this one is good)
PSU=?
So with all you see here. What would you recommend as a power supply without going overboard?. i just want to be able to play games and stuff. I am not going to overclock anything. Please help. the PSU and the Graphics card is my last 2 thing i have to buy then im set. Recommendations? Is this a Good Setup so far?
Also since im new to building a computer. once i boot up the system, is it hard to set UP bios and load drivers? I just learned what bios were so pretend i dont know what im doing when giving advice. HA
PSU=?
