- Aug 1, 2003
- E600000 - E60000FF
If your gonna do a V mod on anything that you'll use a Varible resistor (POT, VR) whateva you wanna call it...
i would recommend that you take an amount of the VR rating you would get and compensate for a fixed resistor to make up for it ..
that way you wont go 0.00 resitance on something and take a MAJOR risk on frying it (not that you dont vmoding anyways )
but say if your gonna use a 15K POT...
i'd go with a 10K pot and a fixed 5K resitor in the line.. that way you cant go below 5K..
For most applications this safeguarding shouldn't interfere whith just how much juice you want to get out of something...
Let's not get crazy here folks..
As for another example on my vcore mod and my vdimm mod i use 10K pot's with 4.7K fixed resistors on the line as well.. that way i dont smoke my cpu or ram..
for my particular setup this means on my cpu the the most gain i can get will be around .5V above whatever my setting in bios is.. even if i turn my 10K pot to zero.. but this is plenty for me .. it will give me right past 2.2V when set to 1.75 but my board has a trip @ 2.17 anyways.. but some boards dont..
