- Feb 20, 2007
- Germany for now.
Here is my little how to on how to build your own standby switch
These can be used to instantly stop all internet traffic to your computer or to your network depending on where you put it...
It is very simple
Materials and tools needed
1. Ethernet Cable
2. Light Switch
3. Screwdriver
4. Tape
5. Scissors
6. Knife
7. 10 minutes of time
so here we go
First take the sheating off of the desired location of the switch. Be sure to take off about 2 inches of sheating. This is Easily done with a knife. Be sure not to cut any wires as it may ruin the cable
Now take your scissors and cut the orange wire
Then take the wire you just cut and take some of the orange sheath off of it
Now prepare your switch by backing the screws out
Now loosely wrap the copper wire around the screw in a clockwise rotation
Then screw the screw down being careful not to break the fragile copper wire
Now do it to the other side
Now it should look like this
Now Put tape around the connections and around the switch and enjoy
This is also known as a lag switch to all of you socom 2 and socom 3 players
It is very simple
1. Ethernet Cable
2. Light Switch
3. Screwdriver
4. Tape
5. Scissors
6. Knife
so here we go
