- Jun 10, 2003
Hi all:
Had a question about my current i7 920 @ 4ghz + r290x in CFX loop. Here is the background:
i7 920 @ 4ghz with raystorm block
2xr290x with xspc full blocks
Rads: 360mm + 120mm + 120mm
ap-15 fans all in push
d800 case
I used to have a gtx 690 in this same loop and temps were generally pretty good even with just 360mm + 120mm on the rads. Anyway, temps really started to go up when I upgraded to the 290x in CFX (not unexpected, since those things generate an unbelievable amount of heat). At load, CPU started to hit 75C+, and the GPUs would be somewhere in the 60C range.
So I added another 120mm rad. Temps didn't really improve - in fact, if anything, they increased. At this point, I figured maybe my d5 vario pump wasn't up to the task (speed setting had always been wonky anyway). So I swapped the d5/xpsc bay res for an mcp-35x/alphacool Repack Dual res. Again, no improvement. A bit stumped here - has adding the third rad added too much restriction in the loop? 120mm not enough extra to decrease the temps - but if so, why would temps even increase a bit?
I've also noticed that the back of the top 290x gets EXTREMELY hot at load.
Any thoughts? Thanks much.
d800 case
