INSANE CRAZY DEAL
@ your local office depot
http://www.officedepot.com/textSearch.do?uniqueSearchFlag=true&Ntt=964344+
on clearence for $200 and has a 100 and 70 dollar REBATE
IMMA GET TWO IF I CAN!!!!!!!
rebates: https://www.web-rebates.com/officedepot/index.asp
Just type 964344 in the Product SKU line on the left, and it should bring up two rebates
Panel type: TFT Active Matrix
Display size: 19"
Diagonal viewable screen size: 19"
Dot pitch: .294mm
Contrast ratio: 450:1
Glass surface: Anti-glare
Horizontal viewing angle: 130 degrees
Vertical viewing angle: 130 degrees
Response time: 16ms
Brightness: 250 cd/m2
Input signals: Analog and DVI-D
Input connector/cable: 15-pin dSub and DVI-D
Maximum non-interlaced resolution: 1280 x 1024 @ 60 Hz
Horizontal frequency: 31.5-80 KHz
Vertical frequency: 56-75 Hz
Power consumption: 56W
Environmental conditions: Operating Temperature: 41-95oF; Operating Humidity: 30-80%; Operating Altitude: 7999 ft
Voltage rating: AC 100-240V, 50/60 Hz
Audio: Stereo speakers built into "soundbar"
Color: Silver
Width: 16.6"
Height: 16.7"
Depth: 7.7"
Weight: 13.2 pounds
Warranty, parts: 1 year
Warranty, labor: 1 year
http://www.amazon.com/gp/product/B0...encoding=UTF8&n=172282&s=electronics&v=glance
Display size: 19"
Dot pitch: .294mm
Response time: 16ms
Color: Silver
Width: 16.6"
Height: 16.7"
Depth: 7.7"
Weight: 13.2 pounds
