Ok so currently my computer is unworkable, here are the symptoms.
*Windows loads fine, however at login the hourglass sits there for a good minute, even though there is nothing to load. The hourglass stops for about 10 seconds then comes on again for another 20 seconds or so. There is no harddrive activity that I can see.
*Anytime I go to run a program (like windows explorer or run - browse - ack! stuck again) the system appears to hang. I have to kill off the process to get it to normalize again.
*I am able to run other programs like IE, but others just won't load properly.
Things I've done recently.....
1.) Loaded a support patch for viewsonic monitors from MS site.
2.) Loaded a beta program I'm doing testing on for MS, which funnily enough all this started happening after I loaded it. Doesn't mean that it's the problem though. It has caused me to
reset my machine quite a few times (20 or so) but
not too much.
Now how should I go about fixing this? I'm really not sure what direction to go in determining what the problem is. I'm guessing it's either the OS is corrupted (first guess), the harddrive has got bad sectors or something causing it the software to act up (second choice), the memory has gone bad and is flaking out (last choice).
I'm scared to start messing with the OS though since that would cause me to have to reload every single driver back onto the system. I WOULD scan the harddrive but I can't get Norton Utlities to function. So what do I do?!
not too much.
