http://www.aziocorp.com/en/keyboards/10-azio-levetron-mech5-gaming-keyboard.html
Feature rich mx cherry black keyboard. Has detachable number pad which is kinda awesome too. For the money, can't be beat imo. I found mine for 74$ during black friday, so I know that some deals will be out there. They are currently out of stock at new egg
http://www.amazon.com/Azio-Levetron...qid=1399661985&sr=1-1&keywords=levetron+mech5
While the 710+ IS a good keyboard, it features less macro buttons, does not have a detachable gamepad, and doesn't have adjustable macro buttons. It IS backlight vs the levetron, however, so if thats important to you, then there you go.
I dunno what this is, but I just had it pop up in my email box today... may be worth checking out!
http://www.newegg.com/Product/Product.aspx?Item=N82E16823162029
Honestly, *MOST* of these keyboards use the exact same switch technology and platform. I can't imagine a K95 "outperforming" a g710+ in anything other than simply having more buttons. Deciding what keyboard type you want is also very important. I, personally, HATE mx cherry brown switches. They are so soft and easy to press and I dont like "hovering" over the keyboard while Im gaming lol. The same can be said against the mx blacks that Im using (its "too hard", less of a clicky sensation vs blues and browns).
Rough synopsis of my thoughts to this :
Browns, blues, and green are very similar. Brown is softer than blue is soft than green.
red, black are very similar with red being softer than brown.
Mx blacks are the "hardest" to press down. That intrigued me for gaming, as an accidental press of a key can cause you to frag yourself. The blues were just far too "soft" for me, as my finger weight alone causes them to press down. As much as I love the "clicky" sound for a moment, after a while it's really annoying compared to just "typing". Mx black and red give you a good typing feel without being obnoxious after 10 minutes.
First thing I noticed when I got the black keyboard was "wow my fingers are tired!", and it took a good week to "get used to it". However, now that my fingers are trained, if I hop on a lighter keyboard I can literally fly haha.
For gaming, I would recommend you get either the brown if you want the "clicky", or red or black if you play fps types.
