- Apr 1, 2008
- Mechanicsburg PA
I'm want to build an HTPC, but I really don't know much about them yet. I have built several gamming PC's though, so I know my way around the build process.
I currently have a Samsung 50" plasma (PN50A650) with a Yamaha RX-V765 Receiver with Bic Acoustech PL-89 Home Theater 7.1 speaker system. & a Samsung BD-2500 blu-ray player.
I would really like to put all my DVD's & now Blu-Ray disc's on a couple of 1TB HDD's & be able to play them through an HTPC hooked directly to my receiver & then to the plasma via HDMI. I may also make this a gamming rig too so I can game on my TV if it is possible to do both.
So far I decided on a SilverStone LC17-B case, but I'm stuck on the MOBO/CPU setup. I have no idea which will be the best for an HTPC I figure the budget will be no more than $1500.00 Once I get some advice on a mobo & cpu that is HDMI compatable the rest should fall into place. I will probably use Vista Home Premium & windows media center until Windows 7 shows up & than go with that.
