- Mar 8, 2006
- CS_Office
hey all!
I just finished installing Damn Small Linux on my Compaq Presario 1270 (older than your grandmother laptop) and I've run into a LOT of problems. I'm hoping you all can help me with step-by-step instructions on how to fix. I know basically NOTHING with Linux so you will have to really dumb it down.
I'll continuously update this first page as problems come and are fixed.
#1) I find DsL's file manager pretty much impossible to use, so I would like to install GNOME on this thing. I don't know how. Can you guys give me a site to download it in deb extension, because apparently deb is all DsL accepts? Also, can you walk me through everything I need to do?
#2) My CD drive and flash drive arent listed- I'm hoping installing GNOME will fix this problem. When I was installing DsL, I did not click on "mount" for either of them on the LiveCD - could this be why? Or is just the file manager's jerkyness?
#3) I downloaded both BitTorrent and LimeWire for Linux in rpm file format, but apparently DsL doesnt like rpm, so I need to use Alien to convert them. Again, can you walk me through what to do, starting with where to get Alien and what format to download it in?
#4a) I plan on taking this thing to WiFi hotspots, so I am wondering if I need any virus protection and what to use.
#4b) I have a network card that resets itself to the HOME IP address every time DsL powers on - how can I save it so that my LAN's IP address is locked?
#5) Upon Bootup, LILO lists the hard drives as Linux and "WinDos (hda2)" - can I change this to "Linux" and "Windows 2000" without uninstalling anything? I'm thinkin it should be just a short change in the lilo.conf file, but I have NO idea how to do that, and dont want to risk screwing up this thing AGAIN. Can you tell me EXACTLY what to do?
#6) Both Linux and 2000 run VERY slowly-would buying some Laptop SDRAM fix this? Also, is all Laptop SDRAM the same, or would I have to be specific?
#7)The Internal PC Speaker always defaults to volume level 64 on bootup, but it annoys me with beeping for (what I think) is no reason. How can I set it up to perminatly say that the PC Speaker volume is 0?
#8) On bootup, DsL does not recognize the resolution of my screen, so it says "Undefined Mode Number - Press Enter to Continue, Space to view modes, or wait 30 seconds" ...if I press enter it works PERFECTLY. How can I set it up so this does NOT pop up on bootup, but instead decides to use whatever video option that it automatically decides on when I press enter?
#9) It states in the lower right hand corner, in the MOUNTED/UNMOUNTED bar, that there is a HDA2 and an HDA5...the HDA2 is Windows 2000, but where did this HDA5 come from? It again annoys me...I could UNDERSTAND if it said HDA1 because thats my DsL partition, but HDA5? WTF?
Yes, I did post some of these questions on the thread "Damn Small Linux" but I was starting to hijack that thread, which isnt good, so here's one all about ME! Woot!
Thanks for your help!
*Edit 10-23-06* Problems #7-9 Added
