- Jan 10, 2012
I have an asus 7850 that i have folded with before, I just installed f@h and the cpu is folding fine, i think I gat a bad wu. I have restared the gpu, rebooted the system and no luck.
here is the log,
*********************** Log Started 2014-07-06T23:45:26Z ***********************
23:45:26:************************* Folding@home Client *************************
23:45:26: Website: http://folding.stanford.edu/
23:45:26: Copyright: (c) 2009-2013 Stanford University
23:45:26: Author: Joseph Coffland <[email protected]>
23:45:26: Args: --open-web-control
23:45:26: Config: C:/Users/CH5-F-Z/AppData/Roaming/FAHClient/config.xml
23:45:26:******************************** Build ********************************
23:45:26: Version: 7.3.6
23:45:26: Date: Feb 18 2013
23:45:26: Time: 15:25:17
23:45:26: SVN Rev: 3923
23:45:26: Branch: fah/trunk/client
23:45:26: Compiler: Intel(R) C++ MSVC 1500 mode 1200
23:45:26: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
23:45:26: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
23:45:26: Platform: win32 XP
23:45:26: Bits: 32
23:45:26: Mode: Release
23:45:26:******************************* System ********************************
23:45:26: CPU: AMD FX(tm)-8350 Eight-Core Processor
23:45:26: CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
23:45:26: CPUs: 8
23:45:26: Memory: 15.91GiB
23:45:26: Free Memory: 13.50GiB
23:45:26: Threads: WINDOWS_THREADS
23:45:26: Has Battery: false
23:45:26: On Battery: false
23:45:26: UTC offset: -4
23:45:26: PID: 2576
23:45:26: CWD: C:/Users/CH5-F-Z/AppData/Roaming/FAHClient
23:45:26: OS: Windows 7 Professional
23:45:26: OS Arch: AMD64
23:45:26: GPUs: 1
23:45:26: GPU 0: ATI:5 PITCAIRN PRO [Radeon HD 7800 Series]
23:45:26: CUDA: Not detected
23:45:26:Win32 Service: false
23:45:26:***********************************************************************
23:45:26:<config>
23:45:26: <!-- Folding Slot Configuration -->
23:45:26: <power v='off'/>
23:45:26:
23:45:26: <!-- Network -->
23:45:26: <proxy v=':8080'/>
23:45:26:
23:45:26: <!-- User Information -->
23:45:26: <team v='32'/>
23:45:26: <user v='caddi_daddi'/>
23:45:26:
23:45:26: <!-- Folding Slots -->
23:45:26: <slot id='0' type='GPU'/>
23:45:26: <slot id='1' type='CPU'/>
23:45:26:</config>
23:45:26:Trying to access database...
23:45:26:Successfully acquired database lock
23:45:26:Enabled folding slot 00: PAUSED gpu:0ITCAIRN PRO [Radeon HD 7800 Series] (paused)
23:45:26:Enabled folding slot 01: PAUSED cpu:8 (paused)
23:45:32:WARNING:Exception: 3:127.0.0.1: Receive error: 10054: An existing connection was forcibly closed by the remote host.
23:45:48:WU01:FS00:Starting
23:45:48:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/CH5-F-Z/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 2576 -checkpoint 15 -gpu 0 -gpu-vendor ati
23:45:48:WU01:FS00:Started FahCore on PID 2420
23:45:48:WU01:FS00:Core PID:3180
23:45:48:WU01:FS00:FahCore 0x17 started
23:45:48:WU00:FS01:Starting
23:45:48:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/CH5-F-Z/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 2576 -checkpoint 15 -np 7
23:45:48:WU00:FS01:Started FahCore on PID 3612
23:45:48:WU00:FS01:Core PID:4332
23:45:48:WU00:FS01:FahCore 0xa4 started
23:45:48:WU01:FS00:0x17:*********************** Log Started 2014-07-06T23:45:48Z ***********************
23:45:48:WU01:FS00:0x17roject: 13000 (Run 509, Clone 0, Gen 58)
23:45:48:WU01:FS00:0x17:Unit: 0x0000005c538b3db753102b794ad4a2a2
23:45:48:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
23:45:48:WU01:FS00:0x17:Machine: 0
23:45:48:WU01:FS00:0x17:Reading tar file state.xml
23:45:48:WU00:FS01:0xa4:
23:45:48:WU00:FS01:0xa4:*------------------------------*
23:45:48:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
23:45:48:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
23:45:48:WU00:FS01:0xa4reparing to commence simulation
23:45:48:WU00:FS01:0xa4:- Looking at optimizations...
23:45:48:WU00:FS01:0xa4:- Files status OK
23:45:48:WU00:FS01:0xa4:- Expanded 884172 -> 1476032 (decompressed 166.9 percent)
23:45:48:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=884172 data_size=1476032, decompressed_data_size=1476032 diff=0
23:45:48:WU00:FS01:0xa4:- Digital signature verified
23:45:48:WU00:FS01:0xa4roject: 9009 (Run 953, Clone 0, Gen 47)
23:45:48:WU00:FS01:0xa4:Assembly optimizations on if available.
23:45:48:WU00:FS01:0xa4:Entering M.D.
23:45:49:WU01:FS00:0x17:Reading tar file system.xml
23:45:49:WU01:FS00:0x17:Reading tar file integrator.xml
23:45:49:WU01:FS00:0x17:Reading tar file core.xml
23:45:49:WU01:FS00:0x17igital signatures verified
23:45:49:WU01:FS00:0x17:Folding@home GPU core17
23:45:49:WU01:FS00:0x17:Version 0.0.52
23:45:54:WU00:FS01:0xa4:Using Gromacs checkpoints
23:45:54:WU00:FS01:0xa4:Mapping NT from 7 to 7
23:45:55:WU00:FS01:0xa4:Resuming from checkpoint
23:45:55:WU00:FS01:0xa4:Verified 00/wudata_01.log
23:45:55:WU00:FS01:0xa4:Verified 00/wudata_01.trr
23:45:55:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
23:45:55:WU00:FS01:0xa4:Verified 00/wudata_01.edr
23:45:55:WU00:FS01:0xa4:Completed 43700 out of 250000 steps (17%)
23:46:49:Saving configuration to config.xml
23:46:49:<config>
23:46:49: <!-- Folding Slot Configuration -->
23:46:49: <power v='full'/>
23:46:49:
23:46:49: <!-- Network -->
23:46:49: <proxy v=':8080'/>
23:46:49:
23:46:49: <!-- User Information -->
23:46:49: <team v='32'/>
23:46:49: <user v='caddi_daddi'/>
23:46:49:
23:46:49: <!-- Folding Slots -->
23:46:49: <slot id='0' type='GPU'/>
23:46:49: <slot id='1' type='CPU'/>
23:46:49:</config>
23:46:50:WU00:FS01:0xa4:Completed 45000 out of 250000 steps (18%)
23:48:31:WU00:FS01:0xa4:Completed 47500 out of 250000 steps (19%)
23:48:56:FS00aused
23:48:56:FS00:Shutting core down
23:48:56:WU01:FS00:0x17:WARNING:Console control signal 1 on PID 3180
23:48:56:WU01:FS00:0x17:Exiting, please wait. . .
23:49:07:WU01:FS00:0x17:Completed 0 out of 5000000 steps (0%)
23:49:07:WU01:FS00:0x17:Lost lifeline PID 2420, exiting
23:49:07:WU01:FS00:0x17:ERROR:103: Lost client lifeline
23:49:07:WU01:FS00:0x17:Folding@home Core Shutdown: CLIENT_DIED
23:49:08:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:49:23:FS00:Unpaused
23:49:23:WU01:FS00:Starting
23:49:23:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/CH5-F-Z/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 2576 -checkpoint 15 -gpu 0 -gpu-vendor ati
23:49:23:WU01:FS00:Started FahCore on PID 4140
23:49:24:WU01:FS00:Core PID:2188
23:49:24:WU01:FS00:FahCore 0x17 started
23:49:24:WU01:FS00:0x17:*********************** Log Started 2014-07-06T23:49:24Z ***********************
23:49:24:WU01:FS00:0x17roject: 13000 (Run 509, Clone 0, Gen 58)
23:49:24:WU01:FS00:0x17:Unit: 0x0000005c538b3db753102b794ad4a2a2
23:49:24:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
23:49:24:WU01:FS00:0x17:Machine: 0
23:49:24:WU01:FS00:0x17:Reading tar file state.xml
23:49:25:WU01:FS00:0x17:Reading tar file system.xml
23:49:25:WU01:FS00:0x17:Reading tar file integrator.xml
23:49:25:WU01:FS00:0x17:Reading tar file core.xml
23:49:25:WU01:FS00:0x17igital signatures verified
23:49:25:WU01:FS00:0x17:Folding@home GPU core17
23:49:25:WU01:FS00:0x17:Version 0.0.52
23:50:15:WU00:FS01:0xa4:Completed 50000 out of 250000 steps (20%)
23:52:02:WU00:FS01:0xa4:Completed 52500 out of 250000 steps (21%)
here is the log,
23:45:26: Bits: 32
23:45:26: CPUs: 8
23:45:26: PID: 2576
23:45:26: GPUs: 1
23:45:26:<config>
23:45:26:
23:45:26:
23:45:26:
23:45:26:</config>
23:46:49:<config>
23:46:49:
23:46:49:
23:46:49:
23:46:49:</config>
23:48:56:FS00aused
