- Jan 17, 2004
Instructions for Windows 8.1 and Windows Phone 8.0 and 8.1 .. Windows 7 will work too but I wrote these off Windows 8.1 (PC not Phone )
Download TetherX from store. (on phone)
Download and put both batch files into a new folder ( you can also place in any folder you choose.
Rename Batch Files with ".bat" ending. EX: Start Tether.txt is renamed to Start Tether.bat
Right Click and choose edit on "Start Tether.bat"
Replace "Your Network Name" with a network name of your choice. ( do not include quotes)
Replace "Your Password" with a network password of your choice.(do not include quotes)
Name new folder whatever you'd like. EX: I named mine Tether Bat Files.
Go into that folder and right click and create shortcuts for both bat files.
Cut and paste both shortcuts onto your desktop.
Right Click and choose properties on shortcuts.
Click Advanced under the shortcut tab.
Now choose "Run as administrator".
Click on the "Start Thether.bat" shortcut to start your network.
Connect to that network via wireless from your phone.
Open and run TetherX and note Proxy address.
Open Browser ( I use IE, yours may vary) choose settings.
Open Internet options.
Click on connections tab.
Click on LAN settings.
Under Proxy section input proxy address and port number that TetherX displays on your phone(app must be open). *NOTE Tether X changes proxy address if you stop and re-start connection so double check correct address was entered.
Close all tabs boxes remaining open if you haven't done so already.
Open browser and enjoy !!
When your done click the Stop Tether.bat shortcut
*** DATA USAGE WILL STILL BE COUNTED AGAINST YOUR PLAN
*** NOT RESPONSIBLE IF YOU GO OVER YOUR DATA LIMIT
let me know if I need to edit anything .. wrote this out real quick like
Thank You to the makers of TetherX .. It gave me the motivation for this post !!
