- Aug 5, 2002
Well just nabbed this today. Going to make this short and sweet because its late, but defiantly more results to follow.
So got the card, had issues with it booting on the PC. Eventually updated the bios and it worked like a charm. Did some resetting back up on the PC and all up and running with my new R9 290 card. I came from a 7950HD doing 1050/1350 roughly.
Figured I'd play around with OCing it right off the bat, so far so good much more tweaking to play with but right now hits around 71C under load on the GPU using default fan speed profile.
Running 1100Mhz/1375Mhz to try it out at first. Seemed to glitch at the tail end of a test so might of pushed the memory a little too much so backed it down to 1350Mhz for ram. GPU voltage I got at 1300mV and power target at 130% right now.
First test was 3DMark Firestrike on Extreme.
Scored nearly 5k. Coming from a 3-3.5k setup that is a nice improvement in benchmark.
Anyways time to hit the sack and look at this more later. One question I will have is on power. Some reason I can't find my 6-Pin connector from my PSU to GPU so right now I am just using a 4-Pin Molex connector to 6-Pin. Nothing else on that connection to the PSU but curious if its safe?
