So this is a PvP last man standing game. You join a server (instructions to follow) and when it fills, everyone is dropped out of a plane together.
Once you land your parachute, you must find gear (you start in civilian clothes with no weapons).
After 10 mins (I could be wrong here... it may be 15 min) you are shown a blue circle on the map and you have 10 mins to get into it. If you stay outside the circle, you take damage until you die.
The circle will continue to shrink every few mins to force player interaction until there is one person left.
A very simple idea but amazing to play.
At the beginning when you are approaching a building to get gear you are thinking 'did someone get here first? Am I going to get shot as soon as I open the door?'.
At the end when the blue circle moves and you are just outside, having to move puts you at great risk. It is easier to see moving targets than someone camouflaged in a bush.
Here is a vid on how to install the mod..
....and finally a full length gameplay vid from a guy I like to watch. He makes it look so calm......it's not.
Please note the run time........
Each game (if you last to the end) is between 45 min to an hour.
If you own Arma III, you are doing yourself a disservice not trying this out.
How are you people doing with FPS in that game, i am planing a new budget build so i am quite interested in the game. Is the engine still ****ty like the arma 2 one, is it even possible to have 50+ fps at all times, since if i remember correctly in arma 2 that was imposible with the hardware available when it came out.
