[Directron] $299 HP Promo ZR2740w 27-inch LED Backlit IPS Monitor 2560 x 1440
Mr.Guvernment
http://www.directron.com/xw476a8aba.html?_s_icmp=dod
HP ZR2740w 27-inch LED Backlit IPS Monitor XW476A8#ABA, 12 ms (gray to gray), 1000:1, HDCP support, with DisplayPort, USB HUB and DVI
When you want the best and brightest displays, you choose HP Performance Monitors. And now we have a new arrival. The HP ZR2740w 27" LED Backlit IPS Monitor is HP's first 27-inch diagonal Performance Series monitor-with a 16:9 aspect ratio and 3.7 million pixels in an ultra-modern and sleek design that perfectly complements HP Z Workstations.
Specifications:
Display size: 27"
Response time: 12 ms (gray to gray)
Display resolution: 2560 x 1440
pixel pitch: 0.233 mm
Brightness: 380 cd/m2
Contrast ratio: 1000:1 static
viewing angle: 1780 horizontal; 1780 vertical
Input signal: 1 DisplayPort in; 1 Dual-Link DVI
Display moving angle: Tilt: -5 to +350; Swivel: +/-450
faceplate treatment: Plug and Play; Anti-glare
I/O ports:
- 4 port USB Hub
- HDCP support on DisplayPort and DVI
Physical security: Security Lock-Ready
Dimensions (w × d × h): 25.4 x 9.3x 17.3 to 21.26 in
