###/### overclocking numbers mean ?
mako777
Im sorry, but the ###/### clock numbers i see people posting.
#1 what do they stand for and what do they effect.
#2 How can i check mine ?
#3 Is there an overclocking settings tool for your video card to addjust these #"s or the input on these #'s.
GPU core speed/RAM speed. Both in MHz. Can be determined by using a program like radclock or something. I forget the best proggy to use..
Also keep in mind that basically all ram speeds are effective and not actual. Look at my signature for example: the memory on my X800 is listed as running 1166mhz. In reality, it's actually running 583mhz, but it's DDR ram so the "effective" speed is double that -- or 1166mhz.
Not that it matters, just more stuff to confuse you :p ;)
