- Jan 5, 2012
- Wales, UK
my system is in my sig, but i have had a h100i installed for a couple of months, i had to get it replaced as my first one developed a problem with its pump
to start with i wasnt blown away by the results at all, i was hitting 90 on a couple of cores within 5 min of prime blend..
i have tried the fans in push or pull, makes no difference, i have reseated it many times, and clean it and the cpu thoroughly each time i do.
i have good airflow in the case with 3x 120 fans pulling air in running at various speeds, and the 2 fans on the h100i exhausting out the top.
i haven't replaced it again because it doesn't seem like there is a problem other than it wont cool my i5 very well at all..
iv actually gone back to stock clocks for now because it still gets up to 65 temps on stock playing games..
i must say.. so far my experiance with these AIO solutions is there really not worth it..
hopefully someone can try and shed some light as to what might be up..
