Vapochill LS install tips?
///M3
Santa Fe, New Mexico, USA
The Vapochill Lightspeed arrived yesterday and after reading the "manual" I definitely need some experienced advice regarding condensation proofing the motherboard and components. I've searched here and found a few suggestions, but will someone offer a comprehensive guide on materials and methods? TIA
it's pretty simple, really. fill the socket and surrounding area with a layer of dilectric grease, and follow the manual's instructions carefully. if you think it through, you should do fine. show us pics!
I just installed my Mach II a few weeks back, just take your time, read as much stuff as you can online (Nuclear's link is great) and have at it. Just check and double check everything and it should be just fine. Good Luck.
