- Jul 25, 2003
- Rio de Janeiro
Me and a good friend, are pondering some theories around the Pentium-M (Dothan) and there are some things we would like verified.
Therefor we need someone with a dead socket 478 motherboard, with a i865 or i875 chipset.
A) Does the motherboard have traces leading to those two empty corner spots / does it have soldering points there?
B) Could you take off the thin plastic socket shim, and look at the larger part under it. does it have holes for the two extra pins in the corner?
Thanks
Scott
Thanks
Scott
