- Aug 19, 2012
Even since i Installed my new 4960X CPU, i have had weird Gremlins that keep cropping up over the last week!!
1, First the Ram does not show in the Bios as Quad set up, then it works again!
2, Next when i change OC Profiles it goes into a loop, and to cure this i have to go into the bios and sort it out myself!
3, Today it was something called CSM PARAMETERS/COMPATIBILITY SUPPORT MODULE!!! What is that??
4, These are some of the issues i have seen so far!!
Now this is my main QUESTION to the members on here, what do you think this could be????
My own idea and Answer would be:
A, The new Bios i installed a few days ago, as it stated more stability, ehh!
B, The CPU and pins not properly contacting etc!!
So what i did today to see if any of my ideas is correct, i have fully cleaned the CPU both sides. And fully checked for miss aligned or bent pins and there was none!
Reseated the CPU after cleaning it and making sure it was fully in line.
Tightened down the WC BLOCK with my fingers this time, and i did not try to give it a tweak, with a Screwdriver.
And while i was typing this message the whole thing just BSOD twice now with no warning at all!!
So please can you help and think of what this can be????
Is this a Windows problem or BIOS PROBLEM as i am thinking it could be!!
Respectfully,
AJ.
Respectfully,
AJ.
