Trying to get the gpu on the go in my project. It is laid on its side, except when it is one ribbon cable just doesn't work, the other loads up but restarts the PC as soon as you start a video. Is it bad luck with shizer cables or are they not designed to run gpu's? Works fine when used directly in the pcie port.
