PROJECT LOG Corsair 750D, Water Cooled, Project "Golden Night" [IN PROGRESS]
DeuS1
Hey Awesome people :thup:
I have now started building my "Golden Night" machine..
It's gonna be a Water cooled Corsair 750D with colour theme "black/gold"
This is my first ever watercooled build, so i'm very excited to get started with it :clap:
Here's a list of what i have so far for the build:
Hardware:
Case: Corsair Obsidian Series 750D
CPU: Intel Core I7 4770K 3.5GHZ 8MB Haswell
GPU: 2 x EVGA GeForce GTX 680 2048MB GDDR5
PSU: Corsair RM Series RM850 850W
Ram: Avexir Core Series GOLD - DDR3-1600, CL9 - 16 GB Kit
MOBO: ASUS Z87-PRO LGA 1150 Intel Z87
OS SSD: Samsung 840 EVO 120 GB
Backup SSD: Samsung 840 EVO 1000GB
Water cooling parts:
CPU: EK-Supremacy Clean CSQ - Acetal
GPU: 2 x EK-FC680 GTX+ - Acetal
GPU Backplate: 2 x EK-FC680 GTX Backplate CSQ - I Am thinking of getting Custom backplates in black, with Nvidia Claw in gold, and gold writing "GTX 680" (work in progress)
Reservoir: EK-RES X3 250ml
Reservoir Top: EK-RES X3 - Multiport TOP
Pump: EK-D5 Vario X-TOP incl. Pump
Rads: Magicool Slim Profile 2X140mm + XSPC EX360 3x120mm
Fittings:
Monsoon Adapter 45 Grad 19/13mm - gold
Monsoon Adapter 45 Grad 19/13mm - black
Monsoon Adapter 90 Grad 19/13mm - gold
Monsoon Adapter 90 Grad 19/13mm - black
Monsoon Push On fitting 19/13mm - black
Monsoon Push On fitting 19/13mm - gold
Monsoon Light Port 45° Rotary Angle Fitting - black - for temperatur sensor
Monsoon Premium G 1/4 Temperatur Sensor - gold
Monsoon Standard Rotary Color Accent Disks - gold
Monsoon Standard Rotary Color Accent Disks - black
Modding:
Bitspower D5 / MCP655 Mod Kit - Gold Finish
2 x 12" cold catodes in yellow, with black sleeved cables
4 x BitFenix 6-Pin PCIe extension cable - sleeved Gold/Black
6 x BitFenix 3-Pin PCIe extension cable - sleeved Gold/Black
1 x BitFenix 24-Pin ATX extension cable - sleeved Gold/Black
2 x BitFenix SATA 3 extension cable - sleeved Gold/Black
Fans:
3 x Corsair Air Series AF120 Quiet Edition High Airflow 120mm Fan
3 x Corsair Air Series AF140 Quiet Edition High Airflow 140mm Fan
3 x Corsair Air Series SP120 Performance Edition High Airflow 120mm Fan
Lamptron FC Touch Fan Controller
So anyways, LETS GET STARTED !!! :attn:
Below is the images of the build process + images of the finished build <3
Hope u like it, please comment :blah:
As a point of advice, no one is going to want to click through all those links. Attaching the images to the post will make things much easier.
Thx, Yep i know, just got frustrated that you could only upload 3 images at a time :) to just tired direct links :-D didnt Work either, so i Will upload 3 at a time later this evening :)
Som minimum kunne du smide
ind, men upload til siden er klart fortrukket.
Looking forward to the end result.
Mange tak :) ..
I Will just upload The images to The site later tonight, once The kid is sleeping :)
You can only pick three at a time, but you can upload three multiple times in the same popup window.
If you need help getting the pictures in-line with text I can help :)
Ooh i see :D awesome, Will look at it tonight :)
Finally found the time to upload the images correctly :)
Hope you enjoy :) ..
will continue building tomorrow :)
The build is now complete <3<3
i will upload images very soon of the final build process and images of the Finished BUILD<3<3
if you have any questions about my thought process during the build, please ask away and ill do the best i can to answer
I had 1 leak from reservoir to the pump, tried 3 times to fix it, but ended up using the old res top with single hole, as the buttom instead, wich fixed the leak ..
i made 2 acryllic plates, covered 1 side of it with carbon foil and put one in the buttom of the case, as a mirror wic reflects all the gold <3<3,
and the other plate i put in the back to cover up the SSD's
Looks great,,
Idle temps
CPU 27 Degrees
GPU 25 Degrees
Load temps
CPU 45 Degrees
GPU 40 Degrees
<3
i have uploaded the images in original post of the final build, hope you like it ! :D
