I went through Corsair's "PSU Finder" and it recommended a 650-750W PSU, but I thought I'd double check here. Also, the Finder doesn't include other ext. cards, devices or drives in its calculation, so it made me wonder a bit.
i7 4930k (probably with slight OC)
Asus x79-Deluxe
GTX 580 Matrix Platinum
32GB 1600Mhz DDR3 RAM (will update to 64GB at some point)
Xonar Essence ST sound card
1 SSD
2 internal HDDs
1-3 external HDDs (connected most of the time)
1 BR/DVD drive
Also, now when we're on the subject, which Corsair's PSU would you recommend? I've been out of the loop for a few years, so I'm not sure which are considered the most reliable nowadays. Sadly I've had quite bad experiences with Corsair's PSUs, especially those considered "very good". For example, currently I have a HX750 and since the start it has had the problem of super-noisy "fan surges" (as described by this dude). And before that I had to RMA two TX650s as both went dead in a month after installing. But I'm still willing to give Corsair a chance, because before these latest problems I never did had any issues with the brand.
Thanks in advance!
Asus x79-Deluxe
1 SSD
2 internal HDDs
1 BR/DVD drive
Thanks in advance!
