- Oct 4, 2011
- Sheffield, England
I am on such a tight budget, I blew 99% of it on new components so a new case would be out of the question at the moment.
I have a Jeantech Aqua case which works great, but with the addition of a Corsair H55 cooler I don't have anywhere I can really fit it.
As you can see from the photo below, this case has no actual space for a 120mm fan, only at the front which cannot be seen in this photo (taken from Google).
The blue circle represents the only 120mm fan space in the entire case.
Here is the photo of my case. I modified the CPU fan space on the side of the case to accommodate the 120mm fan.
To make matter worse is my dremel has broken. I had to make the mounting holes with great difficulty. The screw holes look messy as hell but they're really neat, it's the silicone bushings I fitted that make them look messy.
Can you recommend any kind of way I can fit it? Where is now is so noisy because of the 80mm fan hole restricting the fans capabilities and making it noisier.
I can't believe I have to put up with this ghetto case until I next have money DX
Any help or opinions would be greatly appreciated.
-Fri
-Fri
