hello i have Catalyst version 10.10
i checked for upgrades and then i saw there is 12.4
i remve the old one installed the 12.4 but it says i still have 10.10
i did rebote remove install lot of times but its not helping
I've Been having that problem with 12.4 also. i haven't bothered to uninstall first but normally when CCC does it's auto check and update everything works fine but its still stuck on 12.3. i'm just going to wait till then next update comes out but they've been stuck on this one for awhile now!!!
12.4 has a glitch where it won't report the correct version number even though it updated, you're not the only one it's happened too. 12.4 is a fairly glitchy version.
