Sleep Timer for PC for Windows 7?
MadInsane
Happy Land
Hi all,
Does anyone know of a way (portable freeware app maybe) that sets up a sleep timer for your PC to go to sleep after 30 / 60 / 90 minutes?
I have dual monitors and sometimes fall asleep to movies, etc. so a sleep timer would be great. (You'd think this would be built into windows by now?)
Cheers :thup:
You can use the built in power option to set sleep after x time.
Alternatively, if you don't want it to happen every time:
Open Notepad and make a batch file with the following
Code:
shutdown.exe -s -t 3600
That'll cause sleep after 3600 seconds.
Just run the batch file to start the timer.
Windows does this naturally if you have your sleep/hibernation on... it just needs to be in an idle state.
Thanks guys!! Any way to put it in "Sleep" mode? All the options i saw were "shutdown"
Also, I don't use hibernate due to having SSD, I disabled it to save 10gb of free space
i used to use PSTools. same kind of functionality as the Shutdown command that ATMINSIDE referenced but has a sleep option.
i scheduled the batch file to run everyday at 2:00 am to put computer into sleep mode.
If you want it to do it every time the computer is idle after x time, go to Power Options, Change Plan Settings, and then set a sleep time.
If you want it every now and then, use the batch file I talked about above.
