- Jan 24, 2006
- South Dakota
So I am trying to get out of the mindset of procedural mindset and start working more with objects. I have written a small script which takes a mysql backup, moves it to a remote mount and then checks the size of the backup versus the last backup on the mount point. When it is done it will email a short blurb regarding some info.
I would love some feedback from the more experienced programmers out there as I think peer review is the best way to get better. Before anyone asks, I have not read "Code Complete" yet, it is on my list of books to read in the next little while, so I realize that this will be no way close to being perfect. None-the-less constructive criticism is welcome!
Code:
#!/usr/bin/python
# Owner: stratus_ss
# Date Created: March 21, 2014
# Date Updated: Apr 1, 2014
# Primary Function: Backs up the a database, then transfers it to a mount point
# After the transfer is completed, it will compare the file size to determine the upload
# Was completed successfully
# Secondary Function: This script will also compare versus the last month's backups
# to determine if they are exact same. If so, this is an indication of a problem as
# The database is expected to grow each month, even if only slightly
import sys
import os
import shutil
import datetime
import time
import smtplib
import socket
class initial_operations:
#This class will set the variables that are generic to all processes
def __init__(self):
#This will parse the command line arguments and echo out the usage
try:
self.DATABASE_NAME = sys.argv[1]
self.CRED_FILE = sys.argv[2]
self.SEND_TO_ADDRESS = sys.argv[3]
self.SEND_TO_NAME = self.SEND_TO_ADDRESS.split("@")[1]
self.COPY_FILE = sys.argv[4]
if "yes" in self.COPY_FILE:
self.COPY_LOCATION = sys.argv[5]
except:
print("You did not specify a database name, this is required for proper backup")
print("USAGE: ./backup_mysql_database.py <database name> <credentials file> <email to report to> <copy_file=yes/no> <location>")
sys.exit()
self.START_TIME = str(datetime.datetime.fromtimestamp(time.time()).strftime('%Y-%m-%d_%H:%M'))
self.TODAYS_DATE = str(datetime.datetime.fromtimestamp(time.time()).strftime('%Y%m%d'))
self.BACKUP_DIR = "/DATA/backups/%s" % self.DATABASE_NAME
os.chdir(self.BACKUP_DIR)
#For most servers, the local backups should be kept. For the servers in the databases_to_clean
#list, we only want to keep a single backup between intervals that this script runs
self.TODAYS_BACKUP_FILE = "%s_%s.sql.gz" % (self.DATABASE_NAME, self.TODAYS_DATE)
self.HOSTNAME = socket.gethostname()
def cleanBackups(self, database_name):
#This function exists to clean the database backup directory if required
#At the time of creation only a single database required purging
databases_to_clean = ["EVD_CARGO"]
if database_name.upper() in databases_to_clean:
for FILES in os.listdir("."):
if os.path.isfile(FILES):
os.remove(FILES)
class email:
def __init__(self, backup_instance, message_type):
#This will setup the email messages for sending
#It pulls the variables created earlier to fill in the details
self.message = """From: MYSql Backups <backups@%s>
To: %s <%s>
Subject: Backups completed on %s
The backups are now complete.
""" % (create_variables.HOSTNAME, create_variables.SEND_TO_NAME, create_variables.SEND_TO_ADDRESS, create_variables.HOSTNAME)
if "failed" in message_type:
self.message += """However, the backup size from the previous month is within 500 bytes which may
indicate a problem.
Last Month's backup: %s ---> %s
This Month's backup: %s ---> %s""" % (backup_instance.LAST_MONTHS_BACKUP,
backup_instance.LAST_MONTHS_BACKUP_SIZE, create_variables.TODAYS_BACKUP_FILE, backup_instance.TODAYS_BACKUP_SIZE)
else:
self.message += """The backup is not the same size as last month.
This Month's backup: %s ---> %s""" % (create_variables.TODAYS_BACKUP_FILE, backup_instance.TODAYS_BACKUP_SIZE)
self.send_email()
def send_email(self):
sender = create_variables.HOSTNAME
receivers = [create_variables.SEND_TO_ADDRESS]
try:
smtp_mail = smtplib.SMTP('localhost')
smtp_mail.sendmail(sender, receivers, self.message)
print("email sent")
except Exception, error:
print("email failed to send")
print(error)
class create_Backups:
def databaseActivities(self):
#This function does the mysql dump and gets the file size of the backup for later checking
print(("Process started at: %s" % create_variables.START_TIME))
os.popen("mysqldump --defaults-extra-file=%s -n -R %s |gzip -c > %s " % (create_variables.CRED_FILE,
create_variables.DATABASE_NAME, create_variables.TODAYS_BACKUP_FILE))
END_TIME = str(datetime.datetime.fromtimestamp(time.time()).strftime('%Y-%m-%d_%H:%M'))
print(("Process completed at: %s" % END_TIME))
self.TODAYS_BACKUP_SIZE = os.path.getsize(create_variables.TODAYS_BACKUP_FILE)
def fileCheck(self):
#This section will move the file into the specified location
#It checks the file size versus the previous backup, if the last backup
#size is within 500 bytes, there is assumed to be a problem as for our usage
#databases should always be either growing or contracting.
if hasattr(create_variables, "COPY_LOCATION"):
shutil.copy(create_variables.TODAYS_BACKUP_FILE, create_variables.COPY_LOCATION)
#Find the file after it is moved to the remote location and get the file size
self.MOUNT_FILE = "%s/%s" % (create_variables.COPY_LOCATION, create_variables.TODAYS_BACKUP_FILE)
self.MOUNT_FILE_SIZE = os.path.getsize(self.MOUNT_FILE)
if (self.MOUNT_FILE_SIZE - self.TODAYS_BACKUP_SIZE) != 0:
print((self.MOUNT_FILE_SIZE, self.TODAYS_BACKUP_SIZE))
else:
print("The file sizes are the same")
#Filenames look like this: database_20140122.sql.gz
os.chdir(create_variables.COPY_LOCATION)
latest_backup_date = 0
self.LAST_MONTHS_BACKUP = ''
for backup in os.listdir("."):
#cycle through the backups in the remote directory, exclude today's backup
#Track only the last backup for comparison
if create_variables.DATABASE_NAME in backup and not create_variables.TODAYS_BACKUP_FILE in backup:
backup_date = int(backup.split(create_variables.DATABASE_NAME + "_")[1].split(".")[0])
if backup_date > latest_backup_date:
latest_backup_date = backup_date
self.LAST_MONTHS_BACKUP = backup
self.LAST_MONTHS_BACKUP_SIZE = os.path.getsize(self.LAST_MONTHS_BACKUP)
if (self.LAST_MONTHS_BACKUP_SIZE - self.TODAYS_BACKUP_SIZE) < 500:
print("WARNING!!! Backups are the same size as last month")
email(self, "failed")
else:
print("File sizes are different, emailing 'everything is ok' message")
email(self, "passed")
create_variables = initial_operations()
create_variables.cleanBackups(create_variables.DATABASE_NAME)
run_backups = create_Backups()
run_backups.databaseActivities()
run_backups.fileCheck()
