I'm just wondering if anyone else has had success unlocking the AMD PhenomII x2 545 CPU w/ the MSI 870A-G54 board... I just purchased these 2 components (after much information gathering) and it seemed like this process (unlocking the 3rd and 4th core) was/should be much simpler...
I keep having the same problem:
I go into the BIOS and enable the "Unlock CPU core" option, when I F10 (save and exit) the machine just instantly shuts off for ~5 sec then restarts to blank screen w/ fans running. I can reset my bios via the jumper and it fixes it, bringing it back to base setting, but no unlocked cores.
I have the updated BIOS 17.7 (current) and can't seem to get these cores to unlock / be stable....
thanks in advance!
thanks in advance!
