Hi Guys (& Girls),
Registered as a User several days ago as I couldn't find anything remotely like my situation in the existing threads, but there seems to be some fairly knowledgeable people out there!!!
Bit of a strange one this, but extreme circumstances lead to this possible solution and I need some expert opinion.
Background: I am Brit, living in Greece. Quite nice but has some major drawbacks, main one being the temperature here in summer. Currently 40 and it gets hotter in August. No air con. as it costs a fortune to run here (electricity isn't cheap) so PC runs at around 65 when all 4 cores running 50% usage. But I want to overclock it - AMD2+ m/b, 965(BE) cpu running at stock 3.4gig. I've read that it can be o/c'd to 4.6gig and higher, but I'm not interested in anything too extreme at the moment - probably 4gig to start.
BUT the temperature is the problem. Water cooling seems the answer, but with ambient temperature that high I don't think it'll have much effect. That leads to my idea.
We have an 18,000litre water storage tank under our house. Made from reinforced concrete 25cm thick, it stays at a fairly constant 15 degrees all year round. This tank is immediately below our office.....
My idea is to put a 25metre coil of copper pipe in the tank, feed to the cpu water block also copper, using a central heating circulating pump to move the distilled water around the loop. Small reservoir in the office, probably 10litres. Total cost of around 150euro, but I don't fry my cpu (hopefully).
Does this idea sound solid and has anyone got any suggestions or improvements they could offer?
Many thanks in advance.
