- Dec 7, 2004
My friend told me to download a custom interface, i did and its not the same as his, so i had him send me his and still the same results im missing alot of the menus it seems... heres a screen. how do i fix it?
Secondly are you going to come join your fellow overclockers on Illidan as Horde ?DuckManParkey said:Went with the cosmos, easier to configure, i was using NurfedUI
Would be nice to have you, currently the OC guild is at 37 members and growing so any additions are always welcomeDuckManParkey said:dunno started on hyjil with a friend he said the better guilds are on this realm, im a tauren shamen right now only lvl 7 so i guess i might restart.
ViewtifulMonkey said:cosmos is def. the way to go
13rian said:...until u notice the constant barrage of errors as well as other customizations [standalone] that could suite ur preferences much better that aren't compatible with Cosmos. I couldn't even exit the game properly without an error. Uninstalling not only solved this, but noticed slightly better load time.
I use Gypsy Mod with a crapload of other ui mods (ex.'s mini-map zoom, zoommap, flexbar, xpclock, sellvalue, +10-ish more all found at the official WoW forums).
All we require is that you have fun and help out your fellow guild mate when you are able toDuckManParkey said:MMMMM cant decide if i want to switch, i think i might since im a casual player, and all the serious guilds prolly require mass play time
