- Dec 9, 2002
- Northeast U.S.A.
I have a Kingwin Case with mic, speaker?, usb, firewire, in the front of the case. I think I have it all hooked up except for one thing.
I already connected 2 of the front USB's, one front firewire, the Mic, and the speaker or headphone? connection, all to the back panel of the case. On the Kingwin you go through the case, out the back, and connect to the ports on the back panel.
The only wires left from the front of the case are 4 seperate groups of connections tied into one. I do not know where to hook them. They say:
1. GND USB+ USB- VCC
2. GND USB+ USB- VCC
1. GND
2. GND
The Abit Max 2 ver. 2 Manual says to connect Front Panel Audio Connection header:
1) Audio Mic
2) GND
3) Audio Mic. Bias
4) VCC
5) Speaker Out Right Channel
6) Speaker Out Right Channel Return
7) X
8) NC
9) Speaker Out Left Channel
10) Speaker Out Left Channel Return
11) GND
12) S/PDIF In
13) VCC
14) S/PDIF Out
But, it's different than the 4 connections I have?
Help.
1. GND
2. GND
1) Audio Mic
2) GND
3) Audio Mic. Bias
4) VCC
7) X
8) NC
11) GND
12) S/PDIF In
13) VCC
14) S/PDIF Out
Help.
