- May 23, 2003
What would you suggest I use on a 2-302 heater core? I just got a p182 case and I'm trying to cut the noise to a minumum. The heater core will be external and I plan on running the fans off a rheobus. I'd prefer to stick with two fans not only because of cost but also for quiets sake.
I was thinking of a couple Delta tri blade EFB1212SHE... will these be just as quiet as the low speed model when I lower the volts on the rheobus?
I appreciate the help
